8-Gravel
May 15, 2025 12:02 AM UTC
Is there a way to prevent CADs that have regeneration errors from being imported into Windchill?
Version: Windchill 12.0
Use Case: Register the CAD that has regeneration errors in Windchill.
Description:
Hello.
Engineers are experiencing several issues when checking in CAD files with regeneration errors into Windchill.
We are facing issues with Creo View in Windchill where it is throwing errors or the Iteration of WT PART is not increasing, etc.
Is there a way to prevent CAD files with these regeneration errors from being checked into Windchill?
Thank you
BenLoosliAnswer
May 27, 2025 1:44 PM UTC
ModelCheck takes a bit to understand and setup.
It is included with all licenses.
May 15, 2025 9:23 PM UTC
ModelCheck can prevent check-ins if the error is flagged as an error, depending on how you setup ModelCheck.
8-Gravel
May 23, 2025 2:39 AM UTC
Thank you for reply @BenLoosli
Is the ModelCheck feature a basic feature of CREO?
Is it something that can be automatically blocked even when using automatic check-in?
We don't have CREO Specialist, so I can't find the feature..
BenLoosli23-Emerald IIIAnswer
