18-Opal
Jun 25, 2026 1:34 PM UTC
Is there any configuration required to enable POSASSY/Positioning Assembly publishing in worker
Is there any configuration required to enable POSASSY/Positioning Assembly publishing in worker?
TDTAnswer
18-Opal
Jul 7, 2026 5:12 AM UTC
No worker-side configuration is required.
The only thing required is to publish the object as a Positioning Assembly, either by selecting New Representation in the UI or programmatically using the following API
PublisherAction publisherAction = new PublisherAction();
publisherAction.addAction(PublisherAction.POSASSY, true);
Once the publish request is submitted as a Positioning Assembly, the OOTB publishing process will handle the rest.
The following Help Center topic explains which objects can be configured to publish as Positioning Assemblies using Windchill properties.
Jun 25, 2026 5:24 PM UTC
Yes. You can refer the help center topic.
TDT18-OpalAuthorAnswer
18-Opal
