3-Newcomer
Apr 25, 2015 4:28 PM UTC
Is there anyway to schedule certain windu tasks say on a weekly basis ? (unattended)
Apr 27, 2015 3:15 PM UTC
Hi Nanda,
Is there a specific reason for running the WinDU tasks on a schedule?
What are the specific task you have in mind?
I would think you could make a report similar to check what needs to be checked. (Using Info*Engine/Webjects/ect.)
If you are on a unix system you could write a cron job to run windu.sh, but that would just open the utility, you would need to find a way to send params and run the utility.
I am not sure there is such a way.
Jarrett
3-Newcomer
Apr 28, 2015 5:29 PM UTC
Jarrett,
We want to run some specific tasks, such as unreferenced vault files on a weekly basis, unattended. WINDU seems to have the right mix of operations.
Since it a java program, I was assuming we could run it on a schedule.
I*E is again development, not administration
Nanda
