Mar 18, 2016 11:09 AM UTC
Is Windchill 10.2 M030-CPS05 is compatible with windows 10
Wanted to know, is Windchill 10.2 M030-CPS05 is compatible with windows 10.
There is a planning going on for upgrading windows to 10.0.
Just wanted to know are below mentioned software's compatible with windows 10, links and additional info provided related to it will be very helpful.
Windows 10 platform.
compatibility check for:
windchill 10.2
creo 3.0
fishbowl services, link Access service.
Steffani services.
Thanks.
TomU
Mar 18, 2016 12:38 PM UTC
prawat1-VisitorAuthor
Mar 18, 2016 2:52 PM UTC
Thanks Tom for your quick response,
It would be more helpful if you have idea about compatibility of other software's with windows 10 mentioned in my initial query fishbowl, steffani and link access.
TomU
Mar 18, 2016 3:23 PM UTC
I'm not familiar with Steffani.  As far as linkAccess, I would expect that to have similar compatibility requirements as Creo, since it's using a seat of Creo to do the publishing.  You would probably want to contact Fishbowl directly to confirm:  Fishbowl Technical Support
