6-Contributor
May 29, 2024 10:33 PM UTC
issue in getting Association type between part and epm document
Version: Windchill 12.0
Use Case: i was try to collect the Association type between part and epm document like "owner " or "content" or "image" but it but the value is not coming properly, (ex.) For assembly if association type with a part in UI is "Owner" but while extracting it is showing as "image" some time totally opposite like that .
Description:
HI All,
the code i was using is below:
public static String getAssociationType(EPMDocument epmDoc, WTPart part) {
String associationType = "";
System.out.println("getAssociationType start: "+epmDoc.getNumber());
try {
BinaryLink[] links = findLinks(part, epmDoc);
if (links != null) {
for (BinaryLink link : links) {
AssociationType type = AssociationType.getAssociationType(link);
associationType = type.getLocalizedName(null);
System.out.println("AssociationType: "+associationType);
if (associationType.equalsIgnoreCase("Owner") || associationType.equalsIgnoreCase("Image") || associationType.equalsIgnoreCase("Content")) {
System.out.println("getAssociationType end: "+associationType);
return associationType;
} catch (Exception e) {
System.out.println("Exception in getAssociationType: "+e);
System.out.println("associationType "+associationType);
public static BinaryLink[] findLinks(Object object1, Object object2) {
EPMDocument epmDoc = null;
    WTPart wtPart = null;
    if (object1 instanceof EPMDocument && object2 instanceof WTPart) {
    epmDoc = (EPMDocument)object1;
    wtPart = (WTPart)object2;
    } else if (object1 instanceof WTPart && object2 instanceof EPMDocument) {
    wtPart = (WTPart)object1;
    epmDoc = (EPMDocument)object2;
    if (wtPart != null && epmDoc != null) {
      BinaryLink[] activebinaryLinks = null;
      activebinaryLinks = getEPMBuildRules(wtPart, epmDoc);
      if (activebinaryLinks != null) {
        return activebinaryLinks;
      BinaryLink describedBinaryLink = getEPMDescribeLink(wtPart, epmDoc);
      if (describedBinaryLink != null) {
        return new BinaryLink[] { describedBinaryLink };
    return null;
private static BinaryLink[] getEPMBuildRules(WTPart part, EPMDocument epmDoc) {
    try {
      if (VersionControlHelper.isLatestIteration((Iterated)part)) {
        EPMBuildRule[] epmBuildRule = null;
        QueryResult queryResult = PersistenceHelper.manager.navigate((Persistable)part, "buildSource", EPMBuildRule.class, false);
        if (queryResult != null && queryResult.size() > 0) {
        epmBuildRule = new EPMBuildRule[queryResult.size()];
          byte b = 0;
          boolean flag = false;
          ObjectIdentifier objectIdentifier = PersistenceHelper.getObjectIdentifier((Persistable)epmDoc);
          while (queryResult.hasMoreElements()) {
            EPMBuildRule rule = (EPMBuildRule)queryResult.nextElement();
            if (!flag) {
            flag = PersistenceHelper.getObjectIdentifier((Persistable)rule.getBuildSource()).equals(objectIdentifier);
            epmBuildRule[b++] = rule;
          if (flag) {
            return (BinaryLink[])epmBuildRule;
      LOGGER.error("Error in getEPMBuildRules method :"+e);
    return null;
  private static BinaryLink getEPMDescribeLink(WTPart part, EPMDocument epmDoc) {
    try {
      ObjectReference objectReference = ObjectReference.newObjectReference((Persistable)part);
      QueryResult qr = StructHelper.service.navigateDescribes((Iterated)epmDoc, false);
     // QueryResult qs = PersistenceHelper.manager.find(EPMDescribeLink.class, epmDoc, EPMDescribeLink.DESCRIBED_BY_ROLE, part);
      while (qr.hasMoreElements()) {
        EPMDescribeLink epmLink = (EPMDescribeLink)qr.nextElement();
        WTReference wTReference = epmLink.getRoleAObjectRef();
        if (objectReference.equals(wTReference)) {
          return (BinaryLink)epmLink;
      LOGGER.error("Error in findEPMDescribeLink method :"+e);
    return null;
kindly see my code and tell me what misstake im doing, if you have any other method please share with me
thanks,
Mathivanan
HelesicPetr
May 30, 2024 5:19 AM UTC
Hi @Mathivanan
Try to print version information about the objects, You could find that there can be some old link
PetrH
HelesicPetr
Hi @Mathivanan
PetrH
