avillanueva
23-Emerald II
Apr 14, 2026 7:23 PM UTC
Issue running tmp patch for CS466318
Getting failures applying this patch to my test environment on RHEL 9. Fails with following message:
DEBUG  14-04-2026 13:21:37 - [java] java.lang.RuntimeException: Unable to write to byte cache
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.util.DiskCache.writeByteArray(DiskCache.java:191)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.javac.CompiledClass.<init>(CompiledClass.java:118)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.javac.JdtCompiler$CompilerImpl.createCompiledClass(JdtCompiler.java:344)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.javac.JdtCompiler$CompilerImpl.process(JdtCompiler.java:306)
DEBUG 14-04-2026 13:21:37 - [java] at org.eclipse.jdt.internal.compiler.Compiler.processCompiledUnits(Compiler.java:575)
DEBUG 14-04-2026 13:21:37 - [java] at org.eclipse.jdt.internal.compiler.Compiler.compile(Compiler.java:475)
DEBUG 14-04-2026 13:21:37 - [java] at org.eclipse.jdt.internal.compiler.Compiler.compile(Compiler.java:426)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.javac.JdtCompiler.doCompile(JdtCompiler.java:1020)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.javac.CompilationStateBuilder$CompileMoreLater.compile(CompilationStateBuilder.java:322)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.javac.CompilationStateBuilder.doBuildFrom(CompilationStateBuilder.java:532)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.javac.CompilationStateBuilder.buildFrom(CompilationStateBuilder.java:464)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.cfg.ModuleDef.getCompilationState(ModuleDef.java:423)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.Precompile.precompile(Precompile.java:210)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.Precompile.precompile(Precompile.java:190)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.Precompile.precompile(Precompile.java:131)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.Compiler.compile(Compiler.java:192)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.Compiler.compile(Compiler.java:143)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.Compiler.compile(Compiler.java:132)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.Compiler$1.run(Compiler.java:110)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.CompileTaskRunner.doRun(CompileTaskRunner.java:55)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.CompileTaskRunner.runWithAppropriateLogger(CompileTaskRunner.java:50)
DEBUG 14-04-2026 13:21:37 - [java] at com.google.gwt.dev.Compiler.main(Compiler.java:113)
DEBUG 14-04-2026 13:21:37 - [java] Caused by: java.io.IOException: No space left on device
DEBUG 14-04-2026 13:21:37 - [java] at java.base/java.io.RandomAccessFile.write0(Native Method)
I’ve seen this before first place I looked was my /tmp and /var/tmp folders. I do have noexec on those mounts. I used the variables IATEMPDIR and java command line tmp switches. I can see it using my specified new temp area with oodles of space and open rights. But, I also see folders and execution in /tmp still. I was able to remount with exec option but did not seem to make a difference. Message “No space left on device” still appeared.
Other special details is that I am running with wtSafeArea so I used the special switches indicated in help docs below (TIP: Only specify 1 option):
Usage:
java -jar <patch_jar_filename> [--help]
[--describe]
[--antDebug]]
[--antVerbose]]
[--antOpts <ant_memory_value>]
[--install <product_root>]
[--forceinstall <product_root>]
[--javaHome <java_home>]
[--makeJar <product_root>]
[--recompileRbinfo <product_root>]
[--jsfrags <product_root>]
[--xconfManager <product_root>]
[--safeAreaInstall <product_root>]
[--completeSafeAreaInstall <product_root>]
Options (Only one option can be specified at a time):
-h,--help Displays usage information.
-b,--describe Displays a brief description of the patch.
-d,--antDebug Set ant debug to true.
-v,--antVerbose Set ant verbose to true.
-m,--antOpts Allows user to set the memory options for ANT_OPTS
variable used by ANT. An array of values must be specified
in quotes. For Eg: "-Xms128m -Xmx256m".
-i,--install Installs the patch content and runs configuration actions
that are appropriate for this patch. Must pass in the
product root directory as an argument.
-f,--forceinstall Installs the patch content and runs configuration actions
even though the patch may have previously been installed.
Not applicable for all product patches. Must pass in the
-j,--javaHome Allows user to set JAVA_HOME.
-k,--makeJar Allows user to execute MakeJar.
-c,--recompileRbinfo Allows user to recompile rbInfo files.
-s,--jsfrags Allows user to deploy Jsfrags.
-x,--xconfManager Allows user to forcibly execute xconfmanager.
-a,--safeAreaInstall Safe area mode install extracts the files in patch which
are also site-modified into <install-
dir>/wtSafeArea/ptcCurrent directory. This allows user
time to merge the files modified by the patch with their
site modified files before running the complete safe area
install.
-g,--completeSafeAreaInstall Complete safe area mode install runs the standard patch
install as well as copies the files merged by user in
<install-dir>/wtSafeArea/siteMod to <install-dir>
I did not see any files in the ptcCurrent area created so proceeded ahead with completeSafeAreaInstall. I also did not see space filled up. I put a watch on the folder and sure enough, it filled up /tmp area but immediately cleaned itself up after failure. Sneaky.
avillanueva
23-Emerald II
Apr 14, 2026 8:21 PM UTC
UNCLE!
Ok, I give. I tried even setting TMPDIR to someplace else. Still wants to use /tmp folder. I threw 1GB at it and it finished. For those keeping score at home, here is what I saw when watching the folder for space usage (in MB):
High watermark was 391M: 0->277->345->0->278->391->0
An the run time was about 20 mins. It felt like it was recompiling all of Windchill...in a cave...with a bunch of scraps.
avillanueva
avillanueva23-Emerald IIAuthorAnswer
23-Emerald II
UNCLE!
20-Turquoise
Apr 23, 2026 6:36 PM UTC
When ever I am running a PTC Solution Installer I always do this before running the installer.
\rm -r /opt/ptc/Windchill/tmp_install
mkdir /opt/ptc/Windchill/tmp_install
chmod 777 /opt/ptc/Windchill/tmp_install
export IATEMPDIR=/opt/ptc/Windchill/tmp_install
This way I always have a directory with the proper permissions and in a file system that has enough space.
avillanueva
23-Emerald II
Apr 27, 2026 3:16 PM UTC
Thanks, I did use IATEMPDIR but I think there is a part of the script that must have /tmp hardcoded. Seemed to not fully respect my wishes.
