Nov 8, 2024 2:18 PM UTC
Issue with Updating WTPart in Change Management Process Using Expression
I have an attribute called 'sapnumber' that I use in both wtpart and cadpart.
When a user creates a part and publishes it, they initiate an ECN and start the process of publication. I would like to update my sapnumber within the ECN process using an expression.
The expression will be: sapnumber = (part number + -AA). However, I am constantly receiving an error with this expression.
The expression I got the error from is attached.
Can you help me?
Fadel
23-Emerald II
Nov 8, 2024 5:00 PM UTC
what error ypu get ?
Buiꓘa
Nov 11, 2024 5:40 AM UTC
hello fadel,
I can't actually get to an error. expression skips without executing its function.
Fadel
23-Emerald II
Nov 12, 2024 11:40 AM UTC
hi , you may enable below loggers , to see what the WF is doing :
log4j.logger.wt.workflow.definer=DEBUG
log4j.logger.WF_EXEC_EXPR=DEBUG
log4j.logger.wt.workflow=DEBUG
log4j.logger.wt.workflow.engine=DEBUG
Buiꓘa
