Jan 30, 2024 4:31 PM UTC
Issues with Classification Attribute
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.1
When setting up a binding attribute for partslink classification, if I leave the namespace and node fields blank in the classification constraint, I see the classification attribute in the create new part wizard, but there are no nodes to select. When I add the namespace value to my configured namespace, the classification attribute no longer appears in the new part wizard.
I see no errors in the MS logs
Jan 30, 2024 10:43 PM UTC
Ugh - false alarm.  It came down to licenses, despite using an org admin - still needs a PartsLink license!  Sometimes we overlook the simple things.  Thank you for the responses though!
avillanueva
23-Emerald II
Jan 30, 2024 8:48 PM UTC
Can you share screen shots of your setup? I can compare to mine and then we can see where they are different.
Jan 30, 2024 9:26 PM UTC
See photos below of Type/Attribute setup, Manage Classification window, and New WTPart Wizard.
Attribute Setup.JPGMechanical Node 1.JPGMechanical Node 2.JPGNamespace and Main Node.JPGNew WTPart Wizard.JPGPart Create Layout.JPG
avillanueva
23-Emerald II
Jan 30, 2024 9:46 PM UTC
In the constraint, the default namespace should be "com.ptc.csm.default_clf_namespace". Any reason you used "MyNameSpace"? I left my node field blank.
