Issues with Types, Attributes & Layouts Export and Import in 10.1
All,
We are in the process of migrating from PDMLink 9.1 M050 to 10.1 M010. We are able to resolve many of the issues so far. However we are encountering few issues with the soft attributes / Layouts and transferring them to different environments.
1. We started out with the copy of the Production database, migrated to 10.1 and manually updated the Layout Groups, Layouts (Create, Edit & View) of over 100 types/ sub types of our interest so that we can have them in the desired order with the required data utilities in some cases.
a. We had an issue earlier where updates made to one branch was causing lost attributes in the layouts, but that got better with a PTC supplied class file.
2. Once layouts are configured manually in the initial Development environment, we wanted to export and import into the more formal QA/UAT environment.
3. Found out many issues during this process
a. Attributes from the top most parent (Ex: WTDocument) may show up but attributes from the interim parents (Ex: Reference Document) may be lost.
b. The visibility updates done (ex: Read Only in Edit screens) in source system were not carried forward
c. Updates to the OOTB attributes display names (ex: theCategory) are lost.
d. When updating the layouts in the cluster environment, some of the nodes are not reflecting the change requiring the system restart (Seen this couple of times. Need to explore further).
We tried both ways of exporting. In both case we used Default import method as explained in the documentation
1. Export all required leaf nodes with the flag 'csvExportAncestorTypes' set to true which would export all the parents.
2. Export all the types of interest with the flag 'csvExportAncestorTypes' set to false.
The second approach of export and Import seems to get little better results.
My questions to you all are
1. Have you encountered any of these issues in the system?
2. What did you have to do to make it work?
3. What Export / Import approach seems to work better.
Thanks all in advance. I am really hoping to avoid many manual hours to fix these layouts in all of our environments.
Raju
Raju Pulavarthi
Sr. Systems Analyst - Windchill Team
Global Information Technology
St. Jude Medical
5050 Nathan Lane North
Minneapolis, MN 55442
This communication, including any attachments, may contain information that is proprietary, privileged, confidential or legally exempt from disclosure. If you are not a named addressee, you are hereby notified that you are not authorized to read, print, retain a copy of or disseminate any portion of this communication without the consent of the sender and that doing so may be unlawful. If you have received this communication in error, please immediately notify the sender via return e-mail and delete it from your system.
Raju
Raju Pulavarthi
St. Jude Medical
