Jul 16, 2024 4:23 AM UTC
Isuue about resourse allocation
Version: Windchill 11.1
Use Case: MPM link during add machines and work center i am facing issue with resourse allocation in progress
Description:
MPM link during add machines and work center i am facing issue with resourse allocation in progress,not immidiate to add.
HelesicPetr
Jul 16, 2024 7:49 AM UTC
Hi @vijaykamdi
It seams that there is some performance issue. It could be also a different reason .
It needs to diagnose this behavior, because there are many reasons why it is not added to the operation.
You should contact Windchill admin to check logs, if there are not any interesting information, set the log level to debug or trace and so on.
PetrH
Emeritus
Jul 23, 2024 4:27 AM UTC
Hello @vijaykamdi,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
