ITAR legend on a 3D model?
  • January 20, 2012
  • 2 replies
  • 716 views
Pro/E and Windchill users,
How do you put an ITAR legend on a 3D model; Productview and/or Pro/E model?
In 2D I could use a Format or a Productview stamp but how in 3D models?
Han
Unless it's been removed you should be able to use watermarks. If you have the full PV client installed on a local box, you should have a watermark editor installed with ProductView. Once you create it in there, you export it, then import to WC. I have a document, saved somewhere on my laptop, that I could pass along if I find it.
Chris
Hey Chris, you mention sending a file for watermark.
I have just started trying to get watermarking working. I followed the wvs guide, ptc knowledge base tan's/tpi's, video, etc & cant get it to work.
I posted my files on post: http://portal.ptcuser.org/p/fo/st/thread=53830
If you dont mind, maybe you can send me your file(s) [ini & server_prefs.xml] &/or look at the files I attached at that post & see where I might have messed up. the ini & xml are there, along with a couple images that show vis cfg admin page, mapping, etc.
I would appreciate any help.
If you email yours, please email datajett@aol.com, because I check it more often than the email connected to ptcuser.
Larry Jett
