7-Bedrock
December 4, 2025
Jasper reports dedicated queues.
  • December 4, 2025
  • 5 replies
  • 317 views
Anyone have experience using Jasper report dedicated queues?  I've found this link: https://support.ptc.com/help/windchill/r13.1.1.0/en/index.html#page/Windchill_Help_Center/customization/WCCG_BusLogicCust_ReportGeneration_DedicatedQueueJasperReportScheduling.html
However when I follow the instructions the queues are not created automatically after restarting Windchill.  Not sure if there are other properties that need to be in place?
Best answer by Tom_64
So the resolution was this:
I needed to create a saved report and then create a data monitor for the report..  When I executed the data monitor for the first time the queue was automatically created.
Catalina
Community Moderator
December 9, 2025
Hi
Thank you for your question.
Best regards,
Catalina | PTC Community Moderator
avillanueva
23-Emerald II
December 10, 2025
Did you try creating the queue  yourself? I think the command is just making the association. It could assume that the queue exists. Try that.
Tom_647-BedrockAuthor
7-Bedrock
December 16, 2025
Hi.  Yes I did try creating a queue myself.  I don't believe it is working.  But I'm working with a PTC ticket.  The issue may be I need a data monitor via a saved report which I wasn't doing.  I'm still working it.
Community Moderator
December 16, 2025
Hello @Tom_64,
It looks like you have a response from a community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Tom_647-BedrockAuthorAnswer
7-Bedrock
December 17, 2025
