Dec 2, 2021 3:11 PM UTC
Jasper Studio Java version
Hi team
Following the instructions in
"Authoring Jasper Report Using ReportTemplate"
https://domain/Windchill-HC/en/#page/Windchill_Help_Center%2FWCCG_BusLogicCust_ReportGeneration_JasperCustomization_AuthoringRTemplate.html%23
At step 12 Jasper Studio compiles some Java using class files exported from Windchill 12.0.2 and gives this error:
java.lang.UnsupportedClassVersionError: com/ptc/wbr/datasource/providers/Site_PartReportWNCProvider has been compiled by a more recent version of the Java Runtime (class file version 55.0), this version of the Java Runtime only recognizes class file versions up to 52.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:467)
at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at java.net.FactoryURLClassLoader.loadClass(URLClassLoader.java:814)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at net.sf.jasperreports.eclipse.classpath.JavaProjectClassLoader.findClass(JavaProjectClassLoader.java:335)
at java.lang.ClassLoader.loadClass(ClassLoader.java:411)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:348)
at net.sf.jasperreports.engine.util.JRClassLoader.loadClassForRealName(JRClassLoader.java:190)
at net.sf.jasperreports.data.provider.DataSourceProviderDataAdapterService.getProvider(DataSourceProviderDataAdapterService.java:92)
at com.jaspersoft.studio.data.jrdsprovider.JrdsProviderDataAdapterDescriptor.getFieldProvider(JrdsProviderDataAdapterDescriptor.java:70)
at com.jaspersoft.studio.data.jrdsprovider.JrdsProviderDataAdapterDescriptor.getFields(JrdsProviderDataAdapterDescriptor.java:55)
It looks as if Jasper is compiling using Java8, but the classes exported from Windchill are Java11. I have changed the Jasper project to use Java11 but this error still occurs.
The PTC documented steps don't seem to cover the steps needed to make the Java versions compatible. What is needed to get this working?
thanks -- Rick
Dec 2, 2021 8:01 PM UTC
"Java 8 is being used by Windchill instead of Java 11": https://www.ptc.com/en/support/article/CS332734
rleir17-PeridotAuthor
Dec 4, 2021 11:26 AM UTC
Hi Vladimir
Thanks for the article.
I am seeing the opposite problem: the Windchill exporter is using Java11, which causes problems when I use JasperStudio. I will try using Java8 for the Windchill exporter, that might work.
cheers -- Rick
Dec 4, 2021 11:49 AM UTC
 Hi Rick,
Tell us later what you will get.
