Oct 27, 2023 5:16 PM UTC
Java 11.0.21 allows Windchill to start up without cps 12.0.2.15
For Windchill 12.0.2, the java 11.0.20 update did not allow Windchill to start up.  Per the support articles, it required cps 12.0.2.15 to resolve.  But we tested the new Java 11.0.21 and this one allows Windchill to start up without the cps 12.0.2.15 being installed and Windchill functions are all working.  When I asked tech support, they say R&D has not tested java 11.0.21 yet and has no comment.  My question is...  Do we still need cps 12.0.2.15?  Have others tried java 11.0.21?  Just trying to avoid pushing a cps install to avoid extra installation work.  Thanks for sharing your experience.
jbailey
18-Opal
Oct 28, 2023 10:34 PM UTC
Can verify it was fixed as early as Corretto 11.0.20.9.1.
avillanueva
23-Emerald II
Oct 30, 2023 1:27 AM UTC
This is the article (and links to others) that you are referring to:
https://www.ptc.com/en/support/article/CS398580?source=search
but at the time of this post, PTC has not updated to refer to your finding.
Rocket_Max
Oct 30, 2023 7:38 AM UTC
Hello @ayap
Here is an explanation. If the software matrix or article states that a certain version of Java does not support it, it means that PTC's QA department has not conducted testing and verification.
If there is an article indicating the need to upgrade to a specific version of Windchill or JAVA, please execute it as it will enhance stability
HelesicPetr
Oct 30, 2023 9:03 AM UTC
Hi @ayap
CPS installation is not so complicated process.
PetrH
ayap10-MarbleAuthor
Oct 30, 2023 1:31 PM UTC
the install is complicated if you have a cluster.  need to break the cluster and rebuild the cluster, plus regression testing if you have customizations.
HelesicPetr
Oct 30, 2023 1:41 PM UTC
Hi @ayap
Always you need a break,
PetrH
