May 9, 2016 9:31 AM UTC
java.lang.Exception: deploy failed for (ie) with return code = 1
I get this error java.lang.Exception: deploy failed for (ie) with return code = 1 >
when trying to install Windchill PDMLink 11.0. on to a Windows Server 2012 Std R2 64Bt OS. Can some one help.
Ming
PTCSOLNINSTALLER_PtcInstall
LOG:
INFO   2016-05-09 16:27:30 -
INFO   2016-05-09 16:27:30 - Total time: 30 seconds
INFO   2016-05-09 16:27:30 - Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256M; support was removed in 8.0
DEBUG  2016-05-09 16:27:31 - Installation is Aborting.  The installation cannot continue.
DEBUG  2016-05-09 16:27:31 - 正在中止安裝。 無法再繼續安裝。
FATAL  2016-05-09 16:30:32 - Aborting installation.
FATAL  2016-05-09 16:30:32 - 正在中止安裝。 無法再繼續安裝。
FATAL  2016-05-09 16:30:32 - java.lang.Exception: deploy failed for (ie) with return code = 1
FATAL  2016-05-09 16:30:32 - aborting: original exit_code = 2
FATAL  2016-05-09 16:30:32 - aborting: normalized exit_code = 2
DEBUG  2016-05-09 16:30:32 - SHUTDOWN REQUESTED
DEBUG  2016-05-09 16:30:32 - (X) commiting registry
DEBUG  2016-05-09 16:30:33 - (X) shutting down service manager
DEBUG  2016-05-09 16:30:34 - (X) cleaning up temporary directories
DEBUG  2016-05-09 16:30:34 - Exiting with exit code: 2
DEBUG  2016-05-09 16:30:34 - java.lang.NullPointerException
DEBUG  2016-05-09 16:30:35 - cleanUp()
DEBUG  2016-05-09 16:30:35 - calling cleanUpWin32()
2-Explorer
May 10, 2016 12:32 AM UTC
This does not have enough information on why it failed. Could you attach the complete PSI log and  IE_installer logs from Windchill/Installer/logs directory?
明陳_011-VisitorAuthor
May 10, 2016 2:57 AM UTC
2-Explorer
May 10, 2016 3:18 PM UTC
It looks like the LDAPServer/WindchillDS was down when you ran the PSI. Start the WindchillDS and run PSI in recover option
