Feb 7, 2024 11:45 AM UTC
java.lang.string cannot be cast to java.lang.Integer
Hello, when loading New Document, it gives the error shown in the picture.
I changed the attribute of the document. I made All Attribute data types string. I keep getting the same error. Would you support?
The template is in excel format. All attributes have been inserted..
Best Regards
Selim AKCELIK
egunAnswer
7-Bedrock
Mar 15, 2024 1:12 PM UTC
Hello Selim,
This might be happening due to post-upgrade issues.
try reload the doc preferences on windchill shell by using the command below:
windchill wt.load.LoadFromFile -d <windchill_path>\Windchill\loadFiles\preference.documents.xml
HelesicPetr
Feb 7, 2024 12:00 PM UTC
Hi @selim_akcelik
What about your source input xls file?
What type are the columns ?
PetrH
Feb 7, 2024 12:27 PM UTC
Hello @HelesicPetr
Is this the answer to your question?
HelesicPetr
Feb 7, 2024 12:30 PM UTC
I'm not sure what is Metin
But I would try to use String
PetrH
egun7-BedrockAnswer
7-Bedrock
Hello Selim,
Mar 15, 2024 2:52 PM UTC
Hİ @egun
Thank you for the successful solution.
