Feb 1, 2018 7:52 PM UTC
Java out of date message
I upgraded to Windchill 11.0 m030 last month. Along with that we had IT upgrade Java to 8.144 and IE to 11.0.
Everything is fine except when I got to Vault Configurator. The Java applet opens and then says it is out-of-date and will not run. I have Java set for High Security and the server in the trusted host list. My Windchill system is not on the internet so there is no checking with Oracle servers for a later version of Java.
Does someone know how to shut off this data check and allow me to run the Vault Configurator?
20-Turquoise
Feb 1, 2018 8:28 PM UTC
If you install CPS03 or newer the vault configuration UI has been changed to an html based UI so you won't have to worry about it for the Vault Configurator.
20-Turquoise
BenLoosli23-Emerald IIIAuthor
Feb 1, 2018 8:33 PM UTC
I don't normally do the CPS patches because of the environment we are in.
BUT, this will give me a reason to investigate this one.
One gatchas with doing a CPS?
20-Turquoise
Feb 1, 2018 8:45 PM UTC
I always put them on every month unless they are not supported for upgrade to the next release. ie 11.1 F000 will only upgrade up to 11.0 M030-CPS04. So for now I am stuck on CPS04 if I want to do test upgrades to 11.1 F000.
Installing a CPS almost 2nd nature now. However I have installed many cps's starting with 10.2 F000 and continuing to 11.0 M030. Key is to practice on a rehosted/cloned test server.
1. rehost production server to test
2. install cps on test - take notes
3. if no issues found then install on production using test notes as guide
The time to install a CPS which includes updating our replica file servers takes around 45min to an hr.
