Last Modified Date Unexpectedly Changing
The last modified date on objects is unexpectedly changing when moving the object to a different context. Is this supposed to happen? WC 9.1 M050.
Before Move:
After Move:
TomUAnswer
Forget it. Known bug with 9.1 M050 and M060.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS12557
TomU23-Emerald IVAuthorAnswer
You could argue that by changing context you have modified the data, as it will drive a change in metedata?
Possibly. But it this case only the legacy versions are modified, not the latest at each revision. Furthermore, if you move the objects while inside a folder, this change doesn't occur. It only happens when moving the objects themselves.
