Aug 21, 2024 9:38 AM UTC
LDAP export error
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS22
Getting the below error when trying ldap export or backup from windchill directory server :
You have provided options for scheduling this operation as a task but options provided for connecting to the server's tasks backend resulted in the following error: 'Connect Error'
Here are the errors that I faced
    avillanueva
    23-Emerald II
    Aug 21, 2024 11:22 AM UTC
    Here is an article that details steps: https://www.ptc.com/en/support/article/CS36256
    You can always post the command you were trying here but please leave out details like hostname, username and password. I assuming you checked that those were accurate. Note that WindchillDS is based on OpenDJ. PTC has retired this so anything you find online that is for OpenDJ is almost an exact match.
    Aug 21, 2024 11:40 AM UTC
