Jan 15, 2013 12:45 PM UTC
Learning Windchill Customisation
Hi all,
Can someone guide me whats the basic knowledge that one should have to start learning Windchill Customisation?
I have working and implementing knowledge on the concepts of Windchill and Business administration with a fair knowledge on Java Programming, but still I don't understand how and where to use the Windchill API that are there in the documentation.
Thanks in advance.
Amar Karthi.
GregoryPERASSO
Jan 15, 2013 12:54 PM UTC
Hello
you can have a look also to the "PTC Customizer Guide", which explain how to customize UI, Wizards, add new actions ... and implement business logic behind, where you will use Windchill API
One of a basic exercise is to develop a java bulk loader, to create some objects or links in the Windchill database from for example a CSV file
or to add business logic in Workflow robot. for example test that all related Documents are released, before releasing the state of a WTpart.
regards
Gregory
Jan 16, 2013 9:17 AM UTC
Hi Gregory,
Thanks for your reply.
But can you please explaing me is there any way to understand the Windchill API or a ref doc available for that in PTC's Knowledge base?
regards,
Amar.
Jan 16, 2013 3:55 PM UTC
Windchill and InfoEngine javadocs can be found here once you get an installation up and running.
http://<host>/Windchill/wt/clients/library/api/
http://<host>/Windchill/infoengine/docs/apidocs
To start, I recommend you familiarize yourself with the following packages
wt.fc.*
wt.query.*
In my opinion, knowing how to update and query the database with PTC's persistence mechanisms is crucial. You should also understand how lifecycles and workflows work - and create/test your own. One of the product's biggest selling points has always been the workflow engine.
All of this is backend stuff. I wouldn't know where to begin explaining UI customization without any specific questions.
