Oct 28, 2021 8:42 PM UTC
Lifecycle not picked up from OIR
I created a new context and when I looked at the OIR listing in utilities, it has the same site level ones I created from another product context. The problem is that new objects created in the old context have the proper lifecycles while a part created in the new context shows the lifecycle as One Phase development instead of our modified one from the site?
What can be causing this to happen? The site level OIR should be the defining one and it has the right lifecycle in the file.
Also, how can I switch all the existing parts in the product context to the proper lifecycle? There are about 100 parts already created and checked-in.
I am running Windchill 11.1 M020 CPS20 with Creo 7.0.5.0.
22-Sapphire I
Oct 28, 2021 10:32 PM UTC
Hi Ben, Happy to get on a quick session w/you and take a look if you like - for old times sake 🙂
Make sure the OIR at Product level is enabled.
Look at Composite Rule for the type and examine the Lifecycle template listed
Try disabling the OIR for the type at Site / Org level and create a new object and see what happens
22-Sapphire I
BenLoosli23-Emerald IIIAuthor
Oct 29, 2021 12:43 AM UTC
Thanks,  Mike
Let me try some of those suggestions in the morning and I'll let you know what happens.
