May 5, 2015 3:30 AM UTC
Like Promotion Request for StateChange, Is there a OOTB process for Revision change?
I have a requirement where user will raise a request for a revision change where object will go through approvals and finally get Revised.
May 12, 2015 7:01 AM UTC
Hi
This post will help youRevising Using Workflow
Regards
Vincent
Hi
Regards
Vincent
May 12, 2015 4:36 PM UTC
Avinash,
Are you using PDMLink or Intralink? PDMLink includes Change Management objects OOTB. They are a revision change process like promotions, but that revise the parts. Check into Change Requests and Change Notices. Lots of preferences to control their behavior.
apatil-212-AmethystAuthor
May 13, 2015 2:29 AM UTC
I modified the Promotion request by sending two users for approval in series then added a expression robot to revise the object once approved .
Its working for me.
Thank you guys for your valuable response.
May 13, 2015 11:23 AM UTC
There are some preferences under Promotion Preferences section which deals with Revising the objects during a promotion process. You can also refer to the Promotion Process section in the Customizers guide.
