Apr 26, 2023 9:00 PM UTC
Line Stocks
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.7
Engineer is trying to rename line stock files to include color, type, size in windchill.
Example
236560-RED-AIR-1_2.STK was 236560.STK
It is not changing the name of the linstock in Pro-e, do you know why?
Will it still be connected to the pro-e linstocks if I rename in Windchill, like if I change a property in the lines stock weight/length : .002 was .00325
HelesicPetr
Apr 27, 2023 6:10 AM UTC
Hello @ErikZabokrtsky
If you are talking about Creo data (models) then If you change name in a Windchill you need to synchronize information in the model.
So you need to open the model in Creo to see the change.
If you need to propagate this information to the visualization you need to create new visualization.
Hope that I do not miss the point with pro-e Linstock 😄 and it is not another application.
PetrH
Apr 27, 2023 1:19 PM UTC
Yeah the Engineers all still call Creo by the old name and I just copy/pasted their message to me without editing it haha. I will forward this info on and see if they have any issues. I will update when I hear back from them. Thanks
HelesicPetr
Apr 27, 2023 1:21 PM UTC
@ErikZabokrtsky
Synchronize action is in the workspace and needs to be run if name change is done in the commonspace
PetrH
