Jul 25, 2013 10:01 AM UTC
Load Multilevel BOM Via LoadFromFile
Hello all,
we use LoadFromFile utility to load parts , docs, n BOMs in Windchill.
i have a multilevel BOM.
as below..
I Found on Bom.XMl on PTC TAN: 129544.. Which gives a simple BOM.XML as below..
<?xml version="1.0" ?><!DOCTYPE NmLoader SYSTEM "standard70.dtd">
<NmLoader>
<csvCachePart handler="wt.part.LoadPart.cachePart" >
<csvpartNumber>asmA</csvpartNumber>
<csvpartVersion>C</csvpartVersion>
<csvpartIteration></csvpartIteration>
<csvpartView></csvpartView>
</csvCachePart>
<csvpartNumber>prtC</csvpartNumber>
<csvpartVersion></csvpartVersion>
</csvCachePart>
<csvpartNumber>prtD</csvpartNumber>
</csvCachePart>
<csvOccurrencedAssemblyAdd handler="wt.part.LoadPart.addPartToOccurrencedAssembly" >
<csvassemblyPartNumber>asmA</csvassemblyPartNumber>
<csvassemblyPartVersion>C</csvassemblyPartVersion>
<csvconstituentPartNumber>prtC</csvconstituentPartNumber>
<csvconstituentPartQty>1</csvconstituentPartQty>
<csvconstituentPartUnit>ea</csvconstituentPartUnit>
<csvlineNumber>10000</csvlineNumber>
<csvoccurrenceLocation></csvoccurrenceLocation>
<csvreferenceDesignator></csvreferenceDesignator>
<csvassemblyPartIteration></csvassemblyPartIteration>
<csvassemblyPartView></csvassemblyPartView>
</csvOccurrencedAssemblyAdd>
<csvconstituentPartNumber>prtD</csvconstituentPartNumber>
<csvlineNumber>100</csvlineNumber>
</NmLoader>
This is for only 1 level Child part..
Please any one had done Multilevel BOM Loading Before...Please share the format of MultilevelBom.csv for loading in to Windchill.
Vivek
Jul 25, 2013 1:39 PM UTC
Make sure you use the right DTD for your release. Use standardX10.dtd for 9.0 and 9.1. Use standardX12.dtd for 10.0 and 10.1.
Make sure you load/create any products, folders, users, etc. before loading the parts.
There are multiple ways to create the parts and to create the usage links.
Then load the parts and then the usage links.
Here is a simple way (if you don't care about occurrences).
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
<NmLoader>
<!-- Parts -->
<csvPart handler="wt.part.LoadPart.createPart">
<csvuser/>
<csvpartName>YourTopPart</csvpartName>
<csvpartNumber>YOUR_TOP_PART</csvpartNumber>
<csvtype>separable</csvtype>
<csvsource>make</csvsource>
<csvfolder>/Default/YourFolder</csvfolder>
<csvlifecycle>Basic</csvlifecycle>
<csvview>Design</csvview>
<csvteamTemplate/>
<csvlifecyclestate>INWORK</csvlifecyclestate>
<csvtypedef/>
<csvversion>A</csvversion>
<csviteration>1</csviteration>
<csvparentContainerPath/>
<csvorganizationName/>
<csvorganizationID/>
</csvPart>
<csvuser/>
<csvpartName>YourMiddlePart</csvpartName>
<csvpartNumber>YOUR_MIDDLE_PART</csvpartNumber>
<csvteamTemplate/>
<csvtypedef/>
</csvPart>
<csvuser/>
<csvpartName>YourBottomPart</csvpartName>
<csvpartNumber>YOUR_BOTTOM_PART</csvpartNumber>
<csvteamTemplate/>
<csvtypedef/>
</csvPart>
<!-- Usage Links -->
<csvAssemblyAddLoad handler="wt.part.LoadPart.addPartToAssemblyLoad">
<csvassemblyPartNumber>YOUR_TOP_PART</csvassemblyPartNumber>
<csvconstituentPartNumber>YOUR_MIDDLE_PART</csvconstituentPartNumber>
<csvconstituentPartQty>1.0</csvconstituentPartQty>
<csvcomponentId/>
<csvquantityOption/>
<csvreference/>
<csvassemblyPartVersion/>
<csvassemblyPartIteration/>
<csvassemblyPartView>Design</csvassemblyPartView>
</csvAssemblyAddLoad>
<csvassemblyPartNumber>YOUR_MIDDLE_PART</csvassemblyPartNumber>
<csvconstituentPartNumber>YOUR_BOTTOM_PART</csvconstituentPartNumber>
<csvcomponentId/>
<csvreference/>
</NmLoader>
<NmLoader>
<!-- Parts -->
<csvuser/>
<csvteamTemplate/>
<csvtypedef/>
</csvPart>
<csvuser/>
<csvteamTemplate/>
<csvtypedef/>
</csvPart>
<csvuser/>
<csvteamTemplate/>
<csvtypedef/>
</csvPart>
<csvcomponentId/>
<csvreference/>
<csvcomponentId/>
<csvreference/>
</NmLoader>
Jul 26, 2013 9:56 AM UTC
Patrick is RIght !!!
