Oct 13, 2011 9:05 AM UTC
LoadFromFile : ACL rules loading error
In my Windchill configuration (9.1M060), I have only 1 site and 1 organization.
I want to load some ACL for my organization directly in command line with the LoadFromFile command within a WindchillShell.
First step
Create the XML file csv file with the CSV2XML utility : it's ok.
Following, a sample of the xml file created
<?xml version="1.0" ?><!DOCTYPE NmLoader SYSTEM "standardX10.dtd">
<NmLoader>
<csvAccessRule handler="wt.load.LoadUser.createAccessRule" >
<csvuser>wcadmin</csvuser>
<csvdomain>/Default</csvdomain>
<csvtypeId>wt.epm.EPMDocument</csvtypeId>
<csvpermission>+</csvpermission>
<csvprincipal>MEMBERS</csvprincipal>
<csvpermissionList>7/15</csvpermissionList>
<csvstate>OBSOLETE</csvstate>
</csvAccessRule>
</NmLoader>
Second Step
Load the rules
From a windchill shell, i launch the folowing command :
windchill wt.load.LoadFromFile -d D:\ptc\Windchill\src\loadFiles\CDA_LoaderACL.xml -u <pwd> -p <pwd>
So, I obtain the error :
Principal "MEMBERS" not found.
Méthode de chargement wt.load.LoadUser. createAccessRule a signalé une erreur.
Aucun objet n'a été importé en raison d'une erreur.
Problème inattendu lors de l'exportation/importation.
Exception imbriquée: wt.util.WTException: Méthode de chargement wt.load.LoadUser. createAccessRule a signalé une erreur. E
data file = <D:\ptc\Windchill\src\loadFiles\CDA_LoaderACL.xml,D:\ptc\Windchill\src\loadFiles\CDA_LoaderACL.xml>
map file = <null,null>
token separator = <null,null>
method = <null,create>
user = <null>
Command line = <{}>
Exception imbriquΘeá: wt.util.WTException: Méthode de chargement wt.load.LoadUser. createAccessRule a signalé une erreur.
I don''t undestand the first message concerning MEMBERS : the key MEMBERS exist in the file RoleRB.RB.ser
I have open a PTC call the 11th-Oct-2011. No answer today.
I hope for better luck with the forum.
Thanks for your help
Oct 18, 2011 2:16 PM UTC
I don't think there's a site level principal (group) named MEMBERS. Look in the loadfiles and loadxmlfiles directories. loadfiles/ddl/VariantSpecACL.xml, for example. Under AccessControlRule, there's a WTPrincipalReference entry.
Mar 1, 2013 12:46 PM UTC
Hi Matthew,
I tried VariantSpec example and I am getting the following errors:
D:\ptc\Windchill_10.1\Windchill>windchill wt.load.LoadFromFile -d "D:\ptc\Windch
ill_10.1\Windchill\loadFiles\Option Manager.xml" -CONT_PATH/
3
ill_10.1\Windchill\loadFiles\Option Manager.xml -CONT_PATH/"
Data file not readable "D:\ptc\Windchill_10.1\Windchill\loadFiles\Option Manager
.xml -CONT_PATH/". Error loading data from file.
data file = <D:\ptc\Windchill_10.1\Windchill\loadFiles\Option Manager.xml -CONT_
PATH/,null>
method = <null,null>
user = <null>
Command line = <{}>
.xml -CONT_PATH/".
Can you enlighten?
Mar 4, 2013 5:58 AM UTC
Hi Vincent,
Please try the following,
<?xml version="1.0" ?><!DOCTYPE NmLoader SYSTEM standardX10.dtd>
<NmLoader>
<csvprincipal>teamMembers</csvprincipal>
</csvAccessRule>
</NmLoader>
also, Please load the ACL against of any context (Product or Library).
The below you can try it as .xml file.
<?xml version="1.0" encoding="UTF-8"?>
<Rule>
<AccessControlRule>
<domainName>/Default</domainName>
<externalTypeId>wt.epm.EPMDocument</externalTypeId>
<lifecycleState>OBSOLETE</lifecycleState>
<WTPrincipalReference isInternal="true">
<groupName>teamMembers</groupName>
<groupType>teamMembers</groupType>
</WTPrincipalReference>
<grantPermissionSet>
<AccessPermissionSet>
<permissionField name="READ"/>
<permissionField name="DOWNLOAD"/>
</AccessPermissionSet>
</grantPermissionSet>
</AccessControlRule>
</Rule>
this will also work for you.
BR
MKR
Mar 4, 2013 7:10 AM UTC
Hi MKR,
I m still getting the error which Vincent had.
What has to be written in <csvprincipal> tag? Group name or role name?
Mar 4, 2013 7:11 AM UTC
FYI , I tried the snippet of xml code which u had provided..It still didnt work..giving the same errors
