Oct 17, 2025 8:22 PM UTC
LoadFromFile CSV file format for multiple documents
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.1.2
what is the format for the CSV file to use with LoadFromFile when I have 10 or more documents to load. I can load a single document ok but not when adding another document to the same csv file. file will convert to XML ok but not load?? CSV & XML files attached. MS log as well
    Oct 20, 2025 6:57 AM UTC
    You can follow the step outline in this tech support article. Additionally you can also refer this article.
    Hope this helps.
    regards
    ~Syed
    avillanueva
    23-Emerald II
    Oct 20, 2025 6:50 PM UTC
    No files were attached.
