May 25, 2023 7:58 AM UTC
LOCAL CACHE SYNC
Good morning, we have a problem with local cache sync on Windchill 10.2; if I access Windchill from different workstations i presume that files should be the same but, for some reason, they are not. it seems that local cache cannot be synchronized.
do you have suggestions?
HelesicPetr
May 25, 2023 11:54 AM UTC
Hi @cspinelli
In the workspace there is a utility menu where you can synchronize information between local and server side.
The problem can be that the cache is corrupted .
Another point is that you should know that synchronization is not for updating older version in the workspace.
Sometimes you need to do a update if the workspace contains old versions of a object
This is normal behavior, that the user has to want to update older versions in the workspace.
PetrH
HelesicPetr
May 25, 2023 11:32 AM UTC
Hi @cspinelli
Yes delete the local cache
example "<user_profile>\AppData\Roaming\PTC\ProENGINEER\.wf"
PetrH
cspinelli14-AlexandriteAuthor
May 25, 2023 11:46 AM UTC
thanks but is it normal that the caches don't syncronize?
HelesicPetr
Hi @cspinelli
PetrH
