Feb 23, 2012 1:00 PM UTC
Locking objects in Windchill 10 promotion request workflow template
I am trying to modify our promotion request template which was copied from the OOTB windchill one to lock objects when they are raised up for promotion,a dn then unlocked after they are approved by config management approvers. I have a call into PTC tech support but they are dragging their feet as usual getting back to me. Does anyone have insight into how this can be done. I know that it is some type of robot, and from reading the help, it says you must use tranistion robots in conjuction with the locks, but I am just having trouble putting it all together. The default template contains locks, and unlocks already but not in the places I need them. I tried to copy them and put in line, but something just is not working right. Any help would be greatly appreciated.
Thank you in advance for your assistance,
Buddy Hudson
CAD/PDM Adminstrator
Atlas Copco Drilling Solutions
Feb 24, 2012 10:20 PM UTC
To All,
I received a resolution from PTC today on this one. The fix was creating a new iteration of the life cycle template and include a state called Under Approval which locks down the objects once they are submitted into a promotion request. I would have never had thought to look here. Problem solved though.
Buddy
BuddyHudson1-VisitorAuthorAnswer
To All,
Buddy
Jan 28, 2014 7:23 AM UTC
hello Buddy,
where did you add a state called under approval?at the end?
if possible can you please send me email of the snapshot to chinmay.gadre@bwir.com
also did you modify promotion workflow for the same?
I also want to implement a same solution where in I want to lock affected objects in promotion.
Chinmay
22-Sapphire I
Sep 28, 2016 3:53 PM UTC
Please see attached simple one-page cheat sheet on this that I created 10+ years ago when first studying / playing with how this works.
Promotion with Lock works perfectly and fills the need very well.  Just have to understand how it works.  One might assume that the system actually locks it but it doesn't - it's up to you to configure ACL's (user permissions) at the Lock state.
Sep 28, 2016 4:02 PM UTC
Thank you mike. it is simple super i got it.
But i have one more issue with Browser. can you please have a look same blog.
Best regards
sharan
22-Sapphire I
Sep 28, 2016 4:13 PM UTC
Java is blocking the screens from loading - have to troubleshoot what Java (JRE) is installed and how Java is configured.  Sometimes complex and tricky.
