Nov 11, 2014 8:43 PM UTC
Logging filenames when doing a save or check in/out
Is there a sertting that can be enabled to show the name of the file that is being saved, checked out or checked in in the log files? One of my users says he has lost some work and is positive he checked the files in. If this information was in the log files, I could verify if he did or not in the future.
Nov 25, 2014 7:10 PM UTC
Hi Ben,
You might want to check out the Auditing Event Framework.
Or are you looking for something along the line of verbose logging in MethodServer?
Jarrett
Feb 23, 2015 6:33 PM UTC
Hi Ben,
Following up to see if you were able to use the Auditing utility to achieve the check out/check in actions report.
If you need to see this in some log files you would need to customize the actions to include a println call that would out to the log.
Thank,
Jarrett
