Apr 5, 2017 7:08 PM UTC
Login failed for user, Failed to acquire JDBC connection
Background:
     OLD: Windchill PDM Essentials 10.2 M030 production server
     New:                                        11.0 M020 test server
I have successfully installed Windchill 11.0 on a new VM, imported our SQL database from production to test using Microsoft SQL Management restore/replace function.
On the new test server I have a different SQL password. I've updated that using xconfmanager but still can't login.
"xconfmanager -s wt.pom.dbPassword=<NewPassword> -t db/db.properties -p"
However, I can login using those credentials directly to Microsoft SQL. Any help would be greatly appreciated.
2017-04-05 11:51:31,996 INFO  [main] wt.server.manager.startup - Registry created: RegistryImpl[UnicastServerRef2 [liveRef: [endpoint:[vdst-plm02.corp.vandynesuperturbo.com:5002,wt.boot.WTRMIMasterSocketFactory@1e240](local),objID:[0:0:0, 0]]]]
2017-04-05 11:51:31,996 INFO  [main] wt.server.manager.startup - ServerManager created: ServerManagerImpl[UnicastServerRef2 [liveRef: [endpoint:[vdst-plm02.corp.vandynesuperturbo.com:5002,wt.boot.WTRMIMasterSocketFactory@1e240](local),objID:[0:0:0, 5002]]]]
2017-04-05 11:51:32,011 INFO  [main] wt.server.manager.startup - ServerManager bound in registry.
2017-04-05 11:51:32,011 INFO  [main] wt.manager.CacheMasterNegotiator - Cache master stub name: CacheMaster
2017-04-05 11:51:32,011 INFO  [main] wt.manager.CacheMasterNegotiator - Using low-locking algorithm
2017-04-05 11:51:32,932 ERROR [main] wt.manager.CacheMasterNegotiator - Failed to acquire JDBC connection
com.microsoft.sqlserver.jdbc.SQLServerException: Login failed for user 'WindchillDB'. ClientConnectionId:9bcf6626-f85f-46be-a30a-7ba546b48bb4
  at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:216)
  at com.microsoft.sqlserver.jdbc.TDSTokenHandler.onEOF(tdsparser.java:254)
  at com.microsoft.sqlserver.jdbc.TDSParser.parse(tdsparser.java:84)
  at com.microsoft.sqlserver.jdbc.SQLServerConnection.sendLogon(SQLServerConnection.java:2926)
  at com.microsoft.sqlserver.jdbc.SQLServerConnection.logon(SQLServerConnection.java:2243)
  at com.microsoft.sqlserver.jdbc.SQLServerConnection.access$000(SQLServerConnection.java:42)
  at com.microsoft.sqlserver.jdbc.SQLServerConnection$LogonCommand.doExecute(SQLServerConnection.java:2229)
  at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:5696)
  at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1716)
  at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1327)
  at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:992)
  at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:828)
  at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:1012)
  at java.sql.DriverManager.getConnection(DriverManager.java:664)
  at java.sql.DriverManager.getConnection(DriverManager.java:247)
  at wt.pds.StandardDataSource$1.getConnection(StandardDataSource.java:114)
  at wt.pds.StandardDataSource$ConnectionRetry.execute(StandardDataSource.java:399)
  at wt.pds.StandardDataSource.getConnection(StandardDataSource.java:117)
  at wt.pds.StandardDataSource.getConnection(StandardDataSource.java:83)
  at wt.manager.CacheMasterNegotiator.getNewConnection(CacheMasterNegotiator.java:859)
  at wt.manager.CacheMasterNegotiator.start(CacheMasterNegotiator.java:2268)
  at wt.manager.ServerManagerMain.startServerManager_internal(ServerManagerMain.java:391)
  at wt.manager.ServerManagerMain.run(ServerManagerMain.java:299)
  at wt.manager.ServerManagerMain.main(ServerManagerMain.java:229)
2017-04-05 11:51:32,932 FATAL [main] wt.server.manager - ServerManagerMain abort
Apr 5, 2017 7:56 PM UTC
Check and confirm, if your Database User and Database Password are set correctly in db.properties (On your Windchill 11.0)
~from a Windchill Shell use the "xconfmanager -d <encrypted.password>" command to verify that they are correctly defined
Apr 6, 2017 7:36 AM UTC
The moving from 10.2 to 11.0 is possible only in during the upgrade process.
tclark-21-VisitorAuthor
Apr 6, 2017 3:46 PM UTC
Update and clarification:
Windchill Directory Server starts, HTTP server starts, but the Windchill server will not. See error above.
Question:
Using xconfmanger -s wt.pom.dbPassword......... is that my LDAP password? If so, when I use that property to change/update a password and then open the Control-Panel.bat under WindchillDS, I receive credentials invalid (only way to login is using my initial password upon installation).
Apr 7, 2017 3:19 PM UTC
May be you need to restore your SQL Server user.
SQL for example
USE "wcadmin"
EXEC sp_change_users_login Auto_Fix, 'wcadmin', NULL, 'YOUR_PASSWORD'
go
Apr 25, 2017 11:50 PM UTC
New question/issue:
Almost have my upgrade working but running into this....
wt.org.WTPrincipal  -
The principal <wt.org.WTUser:11> has invalid UFID data that prevents it from being inflated properly.
2017-04-25 17:46:37,012 INFO  [main] wt.pom.properties  - Connection: datastore=Microsoft SQL Server(12.00.4100) jdbcVersion=4.0 driver=Microsoft JDBC Driver 4.1 for SQL Server(4.1.5605.100) driverVersion=4.1
2017-04-25 17:46:45,961 ERROR [main] wt.org.WTPrincipal  -
java.lang.Exception: Stack trace
  at wt.org.WTPrincipal.inflate(WTPrincipal.java:1135)
  at wt.org.WTPrincipal.getAttributes(WTPrincipal.java:625)
  at wt.org.WTUser.setDn(WTUser.java:1708)
  at wt.org.StandardOrganizationServicesManager._principalAdminUser(StandardOrganizationServicesManager.java:11452)
  at wt.org.StandardOrganizationServicesManager._getPersistedPrincipals(StandardOrganizationServicesManager.java:11342)
  at wt.org.StandardOrganizationServicesManager._getPersistables(StandardOrganizationServicesManager.java:11281)
  at wt.org.StandardOrganizationServicesManager._getPersistable(StandardOrganizationServicesManager.java:11259)
  at wt.org.StandardOrganizationServicesManager._getPersistable(StandardOrganizationServicesManager.java:11246)
  at wt.org.StandardOrganizationServicesManager._queryPrincipal(StandardOrganizationServicesManager.java:7741)
  at wt.org.StandardOrganizationServicesManager.getAuthenticatedUser(StandardOrganizationServicesManager.java:2342)
  at wt.org.StandardOrganizationServicesManager.getUser(StandardOrganizationServicesManager.java:2464)
  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  at java.lang.reflect.Method.invoke(Method.java:498)
  at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
  at com.sun.proxy.$Proxy47.getUser(Unknown Source)
  at wt.session.StandardSessionManager.getUser(StandardSessionManager.java:449)
  at wt.session.StandardSessionManager.lambda$setPrincipal$35(StandardSessionManager.java:212)
  at wt.session.StandardSessionManager.setPrincipal(StandardSessionManager.java:229)
  at wt.session.StandardSessionManager.setPrincipal(StandardSessionManager.java:209)
  at com.sun.proxy.$Proxy35.setPrincipal(Unknown Source)
  at wt.session.SessionMgr.setPrincipal(SessionMgr.java:33)
Feb 8, 2019 3:05 PM UTC
I have the same problem. Did you found solution?
