Login on a replica server?
Is it possible for a users to access a replica's web server for Windchill login & access?
In other words, instead of using http://wcmasterserver/Windchill , can remote users go to http://repsite1/Windchill ?
For the fun of I tried. I do get prompted fro credentials, but nothing is accepted.
Even if this were possible, would it improve performance for the remote users?
Gerry
Are you doing content replication only?
Herb Miller
TWeatherford, Inc.
herbm@tweatherford.com
3148 Beach Blvd
Cicero, IN 46034
competitor"
Gerry,
The replica server is only a lite version of windchill when installed. It does not have any users in the LDAP and the LDAP is only installed so that the replica can use the adaptors to communicate with the Master server. You will not be able to login into it, like you would on the master as you found out when you tried. There are several other ways to improve performance for remote users, including indexes, property settings, and etc. I recommend working with PTC for those performance settings
Alexius C. Chukwuka
IT Analyst, Global SAP Basis - TCM
Deere & Company World Headquarters
400 19th St, Moline, IL 61265
Gerry,
The answer is No .
The Replica are the services that run on the background and you can access
the replica server's only through Master.
Mayur
On Fri, Aug 19, 2011 at 8:02 PM, Gerry Champoux
> login & access?
Thanks to everyone that replied.
I expected that this was not possible, but I wanted to make sure I didn't miss anything.
Gerry
In Reply to Gerry Champoux:
