Mar 26, 2014 11:04 AM UTC
Looking for command for intiate publishing \ republishing
Hi ,
We have lot of publish jobs which needs to be re published manually. I am looking for command line utilityfor executing "Publishing and Republishing" for executinga batch of jobs in a single command.
Regards
Manoj
Mar 27, 2014 12:06 PM UTC
What we have been able to do is reset the failed queue entries in the Windchill queues that process publishing requests. This will re-run the publish request by the original user and not create a new queue entry.
Apr 1, 2014 2:00 PM UTC
It's not a command line utillity but we used Publish Scheduler Administrator when we were in trouble with visualization agent in Windchill 9.1.
There you have a lot of preconfigured jobs e.g. PuglishAllPartsNoRepresentation.
Apr 27, 2015 8:56 PM UTC
I've entered case number 12507654 for this request. We keep all failed jobs in the publisher for one week(delete all failed jobs on Saturday night). I can resubmit all failed jobs with a certain "failure" criteria on Friday. There are two phrases I search the job logs for - "was stopped" and "shutting down". I can resend this with success almost all the time! However, I still have the use case where many unrelated cad objects from different contexts need lightweight images...in this case I want the command line prompt to send the list.
