Apr 15, 2015 8:34 PM UTC
Looking for ideas on how to send updates to ERP on checkin
Greetings,
I am looking for ideas on how to update part attributes in ERP automatically when they are updated in Windchill at a given state in the Lifecycle.
Scenario: I have a WTPart at Released State, the same part is already released in ERP. Upon review, the user realizes the Description has typos. This change does not require an ECN or Revision of the part, so, a user with access to change the part updates the attribute and checks the part back into Windchill. Now the change must be made to the ERP part.
How can I have the system automatically update the same part in ERP?
Any ideas are appreciated.
Cam
PLM Solution Architect
Apr 15, 2015 10:10 PM UTC
Hi Cameron
If the use case you described below happens once in a while, ad-hoc publish from the part details page action can be manually selected.
For automating the process, a listener service can be deployed that listens for the new iteration (along with the check for the state) and initiates the workflow that publishes the part details to the ERP.
Hope this helps.
Thanks and best regards
Swamy Senthil
Swasen Inc
swamy.senthil@swasen.com(Email) <">mailto:swamy.senthil@swasen.com(Email)> ; 909 800 8423 <tel:909%20800%208423> (M);
Apr 15, 2015 11:22 PM UTC
Cameron,
How are you getting the released parts over there in the first place?
Are you using ESI or just the Release to Manufacturing? While Swamy is
correct, you might be able to leverage what you already have. Also, I
would hope this is something you are not having to face very often, so
an ad hoc or even manual method may be the most cost effective route.
--Bob
