Sep 19, 2022 8:37 PM UTC
Lost dimensions
Windchill 11.1 M030 CPS08, Creo 7.0.7.0
User has a drawing in a workspace that is fully dimensioned. Checks it out, makes a change so Windchill will think it is modified and then checks it back in. When viewed in CreoView after being published, some of the dimensions are missing. Open the file in the workspace again and the dimensions are there. Open the file in a new workspace and the dimensions are missing.
We have a PDF printed from Creo last week that shows all of the drawing dimensions.
What could cause this?
avillanueva
23-Emerald II
Sep 20, 2022 12:12 AM UTC
How is publishing configured? As-stored or Latest?
Is the publishing user an admin or at least with view all rights to all areas?
Is the user clearing the workspace each time? Default download to a workspace is latest but if the items were already in the workspace, you get those iterations.
Lastly, I see this all the time. Check that the user does not have locally modified (blue plus sign) but not checked out items. When you check in the drawing, the server does not have those local modifications. Looks great in the workspace, but the CAD worker, having the exact same iterations, does not have access to those local modifications that made the drawing correct.
22-Sapphire I
Sep 19, 2022 11:34 PM UTC
Possibly this is for an assembly, and one or more CAD Doc's is not available to the user with the new workspace but is for the user who checked in and to the CAD worker user.
See if there is a difference between Required and All for relationships.
avillanueva
23-Emerald II
22-Sapphire I
Sep 20, 2022 3:06 AM UTC
I read this wrong initially - thanks for clarifying.
This is the key statement by Ben: "When viewed in CreoView after being published, some of the dimensions are missing,"
At Both Alcon and Edwards, I investigated like this many hundreds of times and it was almost always as Antonio states: "Check that the user does not have locally modified (blue plus sign) but not checked out items."
Training and practice for every user every time, really should be:
- Check in
- clear cache, then add same to a new workspace, open in CAD and verify
- verify as-published condition using Creo View
This really should be done by the user but at a minimal by a checker.
