Feb 7, 2024 10:10 AM UTC
Mail Intergration
Hi Guys,
@HelesicPetr
I am looking for the mail intergration, i installed hmail Server (intergrated with Windchill) and configured with Thunderbird. If i send a mail, other person can received that mail, but when i create a promotion request that concern person is not received the notification.
This are the comment which i used:
xconfmanager -t codebase/wt.properties -s wt.mail.mailhost=PDS.name.com:25 -p
xconfmanager -t codebase/wt.properties -s wt.mail.properties=D:\Windchill_12.1\mail.properties -p
xconfmanager -t codebase/wt.properties -s wt.mail.from=Postmaster@$(wt.rmi.PDS.name.com) -p
xconfmanager -t codebase/wt.properties -s wt.workflow.work.UseDefaultNotificationSenderEmail=true
Aj
HelesicPetr
Feb 7, 2024 10:21 AM UTC
Hi @Amirtharaj_K
Does your hmail server use credentials to send a mesages?
if so you need to set a login user with password in the Windchill properties.
xconfmanager -p -s wt.mail.smtp.username=<mail-user> -t codebase/wt.properties
xconfmanager -p -s wt.mail.smtp.password=<mail-user-password>  -t codebase/wt.properties
Or set the hmail server to do not use the login.
I always use a login for emailing and yes I also use hmail server 😄
PetrH
Feb 7, 2024 10:57 AM UTC
Thanks for the replay @HelesicPetr
xconfmanager -t codebase/wt.properties -s wt.mail.properties=C:\Mail_Configuration\mail.properties -p
if i run the above comment i got a output like this in "wt.properties: wt.mail.properties=C\:Mail_Configurationmail.properties"
can u help on this
Aj
HelesicPetr
Feb 7, 2024 11:16 AM UTC
Hi @Amirtharaj_K
You need to use the double "\" in the folder path
for example
"E:\\Windchill_12.0\\creo_view_adapters"
PetrH
Rocket_Max
Feb 8, 2024 1:36 AM UTC
Hi @Amirtharaj_K
This is a very typical email integration problem
  1. Please modify this file <Windchill_Home>\tasks\wt\mail\Sendmail.xml
  2. Find <ie:param name="FROM" data="${@FORM[0]FROM[0]}" default="<%=DEFAULT_FROM%>"/>
  3. Add your Fixed sender <ie:param name="FROM" data="XXX@XXX.xxx" default="<%=DEFAULT_FROM%>"/>
  4. Save it
  5. Restart Windchill and test
https://www.ptc.com/en/support/article/CS410413
Feb 8, 2024 7:32 AM UTC
Thanks for the Replay @HelesicPetr , @Rocket_Max
@HelesicPetrI can see the Email queue in Queue Management, but the status is ready. How can we proceed?
Aj
HelesicPetr
Feb 8, 2024 7:36 AM UTC
Hi @Amirtharaj_K
It will send several times, and then if there is error it fails
If there is no error, it will disappear
The queue is processed by Background method server if it is set. So you should just wait.
Or check the log files if there is any information about emailing. Also you can set a debug level for emailing and check how it goes.
If the background method server is not set then it is processed by Standard Method server and also you need to wait.
PetrH
