Sep 24, 2025 3:51 AM UTC
Mail System not Workings
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.0
Hi Team,
Good Morning !!
We have work on multiple project with many people work on the same and each people directly communication each other with eighter internal team or external team for particular task of same project and we use communication medium as a mail with project subject line. We want to upload each and every communication as a single thread communication on whinchild communication folder. mail System is not working
Here are the errors that I faced
    avillanueva
    23-Emerald II
    Sep 25, 2025 11:24 AM UTC
    How do you envision the upload working? Are they going to continue to send email messages and you want Windchill to process those into discussion threads? Why not just direct users to use discussion threads instead of email? This way they do not need to upload, its direct. Or are the external users the problem since they might not be inside of Windchill, right? Transforming a message into a threaded conversation should not be difficult. I have done this in my system. Your trick will be the mechanism to upload it or listen for emails.
    If you had a "Windchill service account" with an email, listening for emails (custom client), it could receive forwarded or cc'd emails for processing. Very tricky and I can see the logic getting complicated to map in conversations and extract a thread.
    Or you can have a page that takes in an uploaded email file where a user saves off the thread to a file, then goes to Windchill, uploads it and the code transforms it to a conversation. The trick in both cases is dealing with redundant messages, images, etc.
    Emeritus
    Oct 1, 2025 6:05 AM UTC
    Hello @ptc-5040190,
    It looks like you have some response from a community champion. If any of these replies helped you solve your question please mark the reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
