Oct 14, 2015 12:25 PM UTC
Make WC visualization configuration open .pvz files for Creo View by default
I have a problem with the visualization of our .drw files when I open them in Creo View.
- If I open them from Winchill, View shows them in the format .plt but in a quite terrible way as far as fonts are concerned: f.e., fonts are different, phrases overstep title block boxes making them almost unreadable.
- Instead If I open the .drw in Parametric and save it as .pvz and open that .pvz with Creo View (the drw is still displayed as a .plt), the drawing shows up and prints quite well, like in Parametric.
(for this latter way I have these options in config.pro:
  • save_display yes
  • save_drawing_picture_file embed
  • save_model_display shading_high
I enclose here below a video recording of what I am meaning to make it clearer:
Video Link : 6414
--> Hence I deduce that if opened from Windchill, maybe View does not open a .pvz exactly...maybe an other file format (or does not have the above config.pro settings).
Since for us, especially for those who aren't CAD authors, is very comfortable to open and print the drawings directly from Windchill --> Creo View, I am wondering whether there is a way to set up Windchill configurations so as to make it feed Creo View with the format .pvz (so that users can view and print it properly)...or even any workaround to this purpose, if not.
Versions:
Windchill 10.2 M020
View: Lite 3.0 M020 build 23
Parametric 2.0 M110
thanks
bye
TomU
Oct 15, 2015 4:07 AM UTC
Tommaso Leati‌,
The problem isn't .plt vs. .pvz.  In fact, the .pvz is simply a zip file and one of the things it contains is the .plt.  The problem is that you don't have your publisher (cad worker) configured the same was as your normal cad workstation.  You need to install the same fonts (if you've added any), have a similar config.pro file, use pen tables, plotter config files, etc.  You also need to configure a HPGL plotter driver so that Creo will correctly apply your pen tables to the .plt file during publishing.  This is explained in the Creo Adapters guide.  While you can't have TrueType fonts in a HPGL (plot file), stroking the fonts will yield something that under normal circumstances should be virtually identical.
https://support.ptc.com/WCMS/files/156045/en/MCADAdaptersInstallConfigGuide.pdf
From page 250:
tleati12-AmethystAuthor
Oct 19, 2015 7:29 AM UTC
Hi Tom,
thank you for your reply. I tried the change you suggested at page 250 of the document, unfortunately did't work. I think maybe at this point it is really a problem of configuration of my publisherm, with fonts, pentables, plotter config....etc. As I suppose it is a terribly long and delicate work, I will contact my distributor to set up all of this and then give some updates here on how it will go.
thanks
bye bye
