Dec 23, 2014 5:20 AM UTC
Mange Family Table in Windchill ?
In Windchill , we have mapped part_name & part_number as an attribute .
File name : Cad Name
Number : part_number
So that, the attribute will be updated in Windchill based on the value assigned in the parameter list inside the care (Tools-Parameter).
In family table Generic & Instance, we have assigned the value for part_name & part_number (Ex: Part_name: Plate, part_number: 12345).
The value remains same for Generic & Instance.
Since, the parameter part_number: 12345 is same for generic & Instance (Note: enabled WT Parts), not allowing to upload.
It is showing error like"CAD part is not unique".
And we can't assign different part_number for generic & Instance as per our standard.
So, I want to know the best way to handle the family table part like above mentioned scenario
Dec 23, 2014 3:48 PM UTC
Revise your company standards!
The generic ahould be named something that relates to the family type (SHCS.prt) with the instances having the unique names (1254586.prt).
Also, a generic should NEVER be used in an assembly, only an instance. I usually create the generic with weird values just to force the designers to use an instance from the family table.
Dec 23, 2014 9:06 PM UTC
Building on Ben's response... a WTPart for a generic should not be needed. (this may address the issue you're having).
Fully agree on the approach for generic/instances. Unique values of part_number and part_name for each instance and you could probably leave these blank for the generic.
