Mapping rule for skip exporting/importing attributes using Import/Export Management in Windchill
  • March 21, 2025
  • 2 replies
  • 556 views
We are migrating CAD Part (EPMDocument) form source to target system using Windchill Import/Export Management.
The attributes which are available on the source system are not available on the target system and we need to skip them while exporting/importing the CAD Part to get it imported successfully.
We have the option of export/import rules available to create mapping rules to skip the attributes.
Is there any mapping rules to avoid the attributes which are not available on the target system?
In the exported TAG-EPMDocument-0.xml, the attributes which needs to be skipped are available like this:
<businessField>
<businessFieldID>
<solution>WINDCHILL</solution>
<namespace>
<category>type</category>
<name>com.abc.DefaultEPMDocumentMaster</name>
</namespace>
<name>Attribute1</name>
</businessFieldID>
<datatype>java.lang.String</datatype>
</businessField>
Best answer by HelesicPetr
Hi @PD_12915986
You can specify the import rules to ignore IBA parameters
here is the help Mapping Through Special Rules
Excluding a Reusable Attribute Value Named Price from a Reusable Attribute Holder Such As WTPart
<IGNORE_PARENT>
 <tag>ibaPath</tag>
 <path>WTPart</path>
 <value>Price/iba</value>
</IGNORE_PARENT>
In the preceding example, if the following line were deleted, all parent elements in all XML files with <ibaPath>Price</ibaPath> would be excluded:
 <path>WTPart</path>
Hope this can help
PetrH
HelesicPetr
Hi @PD_12915986
<IGNORE_PARENT>
 <tag>ibaPath</tag>
 <path>WTPart</path>
</IGNORE_PARENT>
 <path>WTPart</path>
Hope this can help
PetrH
Community Moderator
March 28, 2025
Hello @PD_12915986
It looks like you have a response from our community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
