Sep 7, 2018 7:26 AM UTC
Mapping WTpart attributes to EPM document
I have a WTpart attribute which stores the corresponding ERP number ERP_number. I would like to show this attribute on the EPM document info page for information only. So I created an alias attribute on the EPM document with the following mapping:
reference^wt.part.WTPart~ERP_number
Unfortunatly, this isn't working. Is the mapping correct?
When I set the attribute on the WTpart, the EPM document is potentially not checked out. I could map the WTpart attribute to the EPM document master and map this again to the EPM document. Seems to me a bit overdone for such a simple requirement...is this the way to go?
Thanks a lot for any hints on how to solve this.
Best
Chris
Feb 7, 2023 1:44 PM UTC
Hi Chris,
I hope you found the answers since you post the question ;). The type of link between WTPart and EPMDocument is certainly the "owner" relationship(not the "reference", so from https://www.ptc.com/en/support/article/CS131355?source=ArticleViewerOthersLiked&sourcearticle=CS38700
  • Note: When the mapping involves soft type attributes ensure that the fully qualified internal names are used in the mapping
    • Example: for mapping WPart subtype (e.g. com.ptc.ptcts.TSPart) attributes (e.g. com.ptc.ptcts.TSAttr) on the associated CAD Document use [builtBy@wt.epm.build.EPMBuildHistory~built^com.ptc.ptcts.TSPart~com.ptc.ptcts.TSAttr] as mapping
the definition would be in your case:
builtBy@wt.epm.build.EPMBuildHistory~built^wt.part.WTPart~ERP_number
