2-Explorer
Apr 28, 2016 8:41 AM UTC
mass edit attributes for WTDocument no convinient in 10.2
In Windchill 10.2, Edit multiple objects can mass edit an attribute, but however, for WTdocument, you have to click the radio box "do not upload file" for each item you select. This is unacceptable when editing 1000+ documents. Any ideas?
(I'm clear that it is easy to write customized code to mass edit an attribute, but I'm finding a way every user could easily access.)
Thanks!
2-Explorer
Apr 29, 2016 12:03 AM UTC
You can set the below preference.
Under attachments, upload primary file on check in. Wouldn't fit for all the use cases, as the users would miss upload primary content during regular check-in.
Regards
Binesh Kumar
2-Explorer
Regards
Binesh Kumar
辉阚_012-ExplorerAuthor
2-Explorer
Apr 29, 2016 12:56 AM UTC
Thank you, this solved my problem.
