7-Bedrock
Feb 19, 2024 9:54 AM UTC
Master exists more than once
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.8
User not able to promote the object.
Getting the error message as:
Error while trying to promote PDMLink objects : Master exists more than once: XXXXX.asm
There is no WT Part availabel for the assembly.
Could you please help to fix the issues.
Thanks in advance.
Thanks & Regards,
Balakrishnan
Here are the errors that I faced
7-Bedrock
Feb 26, 2024 9:31 AM UTC
Thanks for your response.
One of the Assembly instance and related drawing present in level 3 of parent assembly has multiple WT Part connections. The issue got resolved after breaking all the associations.
avillanueva
23-Emerald II
Feb 19, 2024 12:20 PM UTC
Are there any customizations around the promotion request in use? This is just CAD data right?
7-Bedrock
Feb 26, 2024 9:27 AM UTC
Yes, this is only CAD Object. No promotion request is used in this case. Thanks for the followup.
joe_morton
Feb 21, 2024 4:05 PM UTC
Can you share a screenshot?
Does the assembly contain the same child on two different line items?
7-Bedrock
Feb 26, 2024 9:30 AM UTC
One of the Assembly instance and related drawing present in level 3 of parent assembly has multiple WT Part connections. The issue got resolved after removing all of them.
Fadel
23-Emerald II
Feb 22, 2024 10:42 AM UTC
check if you really have duplicate numbers :
select wtpartnumber, count (wtpartnumber) from wtpartmaster GROUP by wtpartnumber ;
select DOCUMENTNUMBER, count (DOCUMENTNUMBER) from epmdocumentmaster GROUP by DOCUMENTNUMBER ;
Do you have any Drawing  associated with multiple WTParts of referenced 3D models with Content / Calculated associations ?
Buiꓘa
ptc-45508287-BedrockAuthorAnswer
7-Bedrock
