Mar 13, 2018 10:42 AM UTC
Maximum how many windchill users can be registered at once by modifying parametric.psf file ?
Hi all,
<default .wf folder is register with userone credentials> (userone successfully logged in)
<modified .psf file with another path registered with usertwo credentials> (usertwo successfully logged in)
ENV=PTC_WF_ROOT=<path>
ENV=PTC_WLD_ROOT=<path>
ENV=CREO_AGENT_HOME=<path>
<modified .psf file with another path registered with userthree credentials> (message: server already registered with usertwo credentials)
ENV=PTC_WF_ROOT=<differentpath>
ENV=PTC_WLD_ROOT=<differentpath>
ENV=CREO_AGENT_HOME=<differentpath>
using these user configuration in parametric.psf file I am able to login with two windchill credentials now while server cache being registered at two different locations. But when I specified third location and tried to launch creo parametric 4.0 with new user credentials, it's displaying a message server already registered to 'older user'. Even though I have specified different location why is it taking older cache location? How many users can be maximum registered at once?
TomU
Mar 13, 2018 12:19 PM UTC
The environment variables for the Creo Agent in Creo Parametric 4.0 are different.
ENV=CREO_AGENT_EXE_PATH=H:\Creo 4.0\M040\Agent\creoagent.exe
ENV=CREO_AGENT_LDP_LIST=H:\Creo 4.0\M040\Platform\4\manifests
https://www.ptc.com/en/support/article?n=CS257485
https://www.ptc.com/en/support/article?n=CS255889
Vinay_S1-VisitorAuthor
Mar 13, 2018 12:57 PM UTC
Hi Tom,
I think so you did not get my question. Let me explain it clearly.
I have integrated windchill within creo. When we register server, a folder called .wf will be created in appdata which will hold all my server and current session information. This .wf folder is for a particular user. By modifying parametric.psf file I can specify a directory to store another user information without unregistering the initially registered server.
That is if initially userone has registered with windchill server , a folder called .wf will be created to store his information. Next when usertwo registers another folder in a specified location will be created automatically and will hold all his information. Now  without unregistering userone I can add usertwo to use the same server using this method.
Now my question is how many such users can be added by modifying the parametric.psf file. Because when I tried to register userthree, folder specified was not getting created and I was getting a messagebox which specified already this server is registered with xyzuser. Do you want to continue or ignore.
Mar 13, 2018 2:38 PM UTC
Each user on their machine will use the 'same' cache file names, so you do not need to modify the .psf for multiple users. Even if users share a computer, assuming individual OS logins, they will each have their own cache files.
The only time I see your error message is when I use multiple Windchill accounts on the same computer login. This should be a rare instance, but I have it because of my admin versus normal user account.
