Feb 6, 2024 4:32 PM UTC
Maximum Limit to file deletion in Common Space
All,
I imported a big assembly into Creo and uploaded to Windchill. It's a lot of files. I no longer need this assembly. I can't delete by selecting all files because it appears there are several pages of files and I don't think it is selecting those files on following pages and is looking for the files it is referencing that it can't see. I tried to delete the folder itself. It appeared to be deleting the folder and the files within. However, it said I have reached the maximum limit for deleting files. I am not sure if I am being clear. Anyone know how to delete a folder that contains a large amount of files?
WayneF
HelesicPetr
Feb 7, 2024 11:34 AM UTC
HI @wfalco
I've never see that error before. So what Windchill version do you use?
I would recommend you to move all files to folder and delete it.
There can be just few limits. Method Server Garbage memory and SQL query limitation.
You can all increase.
I needed to delete over 300 000 wtparts at one shot, and I needed 8GB memory for one MethodServer to do so.
PetrH
avillanueva
23-Emerald II
Feb 7, 2024 12:26 PM UTC
I would agree that there is no delete limit but could be too much to do in one shot, query limit or memory. I would suggest doing it in chunks to whittle it down. If you run into issue with dependent objects, you can use the collector to grab those.
wfalco16-PearlAuthor
Feb 7, 2024 1:22 PM UTC
The files are in one folder and they are not referenced by anything else in Windchill. Since I truly can not select all because they are on 4 pages. I can't select all of page 1 because I would run into dependents. I did think about using a collector. But I am not sure how to do that. I have 5 main assemblies actually. I can't grab sub-assembies and it's dependents because they belong to the main assembly. I'm not sure how to use a collector either. I was thinking of opening the assemblies and deleting everything to remove all dependancies.
