Apr 10, 2014 11:33 AM UTC
Method Server crashes after Rehosting on WC start as error Invalid object name 'Repository'
Hi Everybody,
I have an issue to start the MS on the target server after Rehosting is completed.
Please help to resolve. Attached the MS lo
Source and Target Server Environment :
WC : 10.1 M030
OS : Windows 2008 R2
SQL Server 2008 R2
Steps followed :
1) Export the LDAP manually.
2) Imported the source LDAP successfully to Target.
3) Database backed up via SQL server Management Studio.
4) Restored the database successfully.
5) Run the ant file –
ant "-Dtarget-ldap=ldap://cn=manager:xxxx/" -Dtarget-domain=xxxx
6) Modified the db.properties appropriately.
7) Started the Windchill as service.
Fails to start with Method server failure with the below error message :
wt.services.ManagerException: Could not initialize Auditing service.
Nested exception is: wt.ufid.UfidException: A persistence error occurred.
Nested exception is: (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Nested exception is: wt.pom.DatastoreException: A SQL error has occurred for the statement "SELECT 'wt.ufid.Repository',A0.displayName,A0.guid,A0.lastKnownDomain,A0.local,CONVERT(varchar,A0.createStampA2,120),A0.markForDeleteA2,CONVERT(varchar,A0.modifyStampA2,120),A0.idA2A2,A0.updateCountA2,CONVERT(varchar,A0.updateStampA2,120) FROM Repository A0 WHERE ((A0.guid = ?)) AND (A0.markForDeleteA2 = 0); Bind Parameters=[Ldap.mm.local]". Database system message follows:
Nested exception is: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'Repository'.
Apr 10, 2014 12:57 PM UTC
Change the hostname setting in wt.proprties ->
java.rmi.server.hostname=mmiplpdmtest01.mm.local
in
java.rmi.server.hostname=hostname of your site (example : pdm.world.com)
Regards
Pascal
taruchamy12-AmethystAuthor
Apr 11, 2014 4:12 AM UTC
Hi Pascal,
Thanks for the reply.
Though I did not mention in the steps, java.rmi.server.hostname was already set 😞 to the target machine.
Murthi
Apr 10, 2014 4:58 PM UTC
On startup, Windchill is connecting to the DB and is trying to query the Repository table. But SQL Server is saying that it doesn't know of any table with this name. Log into this Database through the SQL Server Management Studio and try running the query:
SELECT * FROM Repository;
If this returns the same 'Invalid object name' error message, then something must have gone wrong when importing the DB on the target system. If this query does successfully return entries, then check the DB related settings in db.properties.
Apr 10, 2014 6:02 PM UTC
During rehost after schema import, I run following in database. Check if it helps you.
update repository set lastknowndomain='<TagetServerName>' where local=1;
Apr 11, 2014 4:18 AM UTC
Hi Yogesh,
The value of LastKnown Domain was updated already as the target machine.
Still the issue exists ...
Murthi
Apr 11, 2014 6:25 AM UTC
I think there is a problem with the import of the Database or the schema used. Invalid object name means that the database user can't access the repository table.
As a simple test try to query the table repository with your credentials.
Apr 11, 2014 6:28 AM UTC
Hi Herbert,
As I mentioned above, I was able to connect to the database via SQL Management studio and I can access and query the specific table info. with the same user I mentioned in the db.properties.
Murthi
Apr 11, 2014 6:31 AM UTC
Maybe there is an issue with the default schema:http://social.msdn.microsoft.com/Forums/sqlserver/en-US/5e760744-442b-44c7-8116-77136e12a898/error-invalid-object-name-tablename-but-the-tables-exist-in-the-database?forum=sqlgetstarted
Sorry i'm not familiar with sql server and don't know the settings in windchill
