Method Server Fails to Start after Update from Windchill 10.1 M040 to Windchill 10.1 M050
- 6 replies
- 3468 views
- Translate All
Hi All,
Today, i have sucessfully update Windchill 10.1, from 10.1M040 to Windchill 10.1M050.
When, i start the Windchill, method server was not up.
MS Log file is in attachment.
Please help us to solve this.
In MS logs, below is error :
ested exception is: A persistence error occurred.
Nested exception is: (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Nested exception is: A persistence error occurred.
Nested exception is: wt.util.WTException: (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Nested exception is: wt.pom.DatastoreException: A SQL error has occurred for the statement "SELECT 'com.ptc.swlink.scm.ContainerAttributeLink' FROM (SELECT 'com.ptc.swlink.scm.ContainerAttributeLink' classname FROM DUAL WHERE (NOT (EXISTS (SELECT B0.idA2A2 FROM ContainerAttributeLink B0)))) A0; Bind Parameters=[]". Database system message follows:
Nested exception is: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:447)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:951)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:513)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:227)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:531)
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:208)
at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:886)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1175)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1296)
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3613)
at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3657)
at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1495)
at wt.pds.AbstractResultCursor.executeQuery(AbstractResultCursor.java:518)
at wt.pds.BasicResultCursor.getNextResultSet(BasicResultCursor.java:282)
at wt.pds.BasicResultCursor.advance(BasicResultCursor.java:234)
at wt.pds.BasicResultCursor.next(BasicResultCursor.java:82)
at wt.pds.SQLDatabasePds.query(SQLDatabasePds.java:687)
at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1108)
at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1017)
at wt.pom.EmptyTableManager.queryTables(EmptyTableManager.java:540)
at wt.pom.EmptyTableManager.queryTables(EmptyTableManager.java:491)
at wt.pom.EmptyTableManager.findEmptyTables(EmptyTableManager.java:588)
at wt.pom.EmptyTableManager.populateCache(EmptyTableManager.java:133)
at wt.pom.EmptyTableManager.access$100(EmptyTableManager.java:83)
at wt.pom.EmptyTableManager$AllManagersStartedEventListener.notifyVetoableEvent(EmptyTableManager.java:689)
at wt.events.StandardKeyedEventBranch.intDispatchEvent(StandardKeyedEventBranch.java:320)
at wt.events.StandardKeyedEventBranch.dispatchVetoableEvent(StandardKeyedEventBranch.java:229)
at wt.events.StandardKeyedEventDispatcher.intDispatchEvent(StandardKeyedEventDispatcher.java:286)
at wt.events.StandardKeyedEventDispatcher.dispatchVetoableEvent(StandardKeyedEventDispatcher.java:215)
at wt.services.StandardManagerService.intDispatchVetoableEvent(StandardManagerService.java:406)
at wt.services.StandardManagerService.dispatchVetoableEvent(StandardManagerService.java:302)
at wt.services.StandardManagerService.performStartupProcess(StandardManagerService.java:184)
at wt.services.StandardManager.startup(StandardManager.java:459)
at wt.services.StandardServicesHandler.start(StandardServicesHandler.java:44)
at wt.method.MethodServerMain.run(MethodServerMain.java:506)
at wt.method.MethodServerMain.main(MethodServerMain.java:311)
Vivek
