Method server fails to start with FATAL [main] wt.server.manager.shutdown - ServerManager stopped.
- 3 replies
- 1468 views
- Translate All
2023-06-19 11:36:08,590 FATAL [main] wt.server.manager - ServerManagerMain abort com.microsoft.sqlserver.jdbc.SQLServerException: Login failed for user 'wc'. ClientConnectionId:a7ebdb5b-4d75-41e5-858b-4753b6892a4c
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:262)
at com.microsoft.sqlserver.jdbc.TDSTokenHandler.onEOF(tdsparser.java:283)
at com.microsoft.sqlserver.jdbc.TDSParser.parse(tdsparser.java:129)
at com.microsoft.sqlserver.jdbc.TDSParser.parse(tdsparser.java:37)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.sendLogon(SQLServerConnection.java:5067)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.logon(SQLServerConnection.java:3731)
at com.microsoft.sqlserver.jdbc.SQLServerConnection$LogonCommand.doExecute(SQLServerConnection.java:3675)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7194)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2979)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:2488)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:2142)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:1993)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:1164)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:760)
at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:677)
at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:228)
at wt.pds.StandardDataSource$1.getConnection(StandardDataSource.java:115)
at wt.pds.StandardDataSource$ConnectionRetry.execute(StandardDataSource.java:411)
at wt.pds.StandardDataSource.getConnection(StandardDataSource.java:118)
at wt.pds.StandardDataSource.getConnection(StandardDataSource.java:84)
at wt.manager.CacheMasterNegotiator.getNewConnection(CacheMasterNegotiator.java:875)
at wt.manager.CacheMasterNegotiator.start(CacheMasterNegotiator.java:2375)
at wt.manager.ServerManagerMain.startServerManager_internal(ServerManagerMain.java:390)
at wt.manager.ServerManagerMain.run(ServerManagerMain.java:298)
at wt.manager.ServerManagerMain.main(ServerManagerMain.java:228)
2023-06-19 11:36:08,593 FATAL [main] wt.server.manager.shutdown - ServerManager stopped.
