May 7, 2012 1:28 PM UTC
Method server logging abnormally large amounts of data
All,
Recently our method server has been logging abnormally large amounts of data - It will fill a 9MB MethodServer log file in about 1 minute often from the actions of a single user who is not even checking data in. Some days over 1 GB of data will be logged and on other days with similar activity levels there might be less than 20 MB.
All the extra data falls into these two categories apparently having to do with Pro/E units and PV thumbnails:
Fri 5/4/12 15:07:24: SimpleTaskDispatcher6: INFO : com.ptc.windchill.uwgm.proesrv.util.UwgmNDUtilities - UwgmNDUtilities.getQuantityType :: kg/m**3: units = kg/m**3; symbol map = {kg=1, m=-3}
Fri 5/4/12 15:07:24: SimpleTaskDispatcher6: WARN : com.ptc.windchill.uwgm.proesrv.util.X12NeutralDataHelper - X12NeutralDataHelper.createModelParameters :: DENSITY: valueType = uwgmdb::DataType::RealWithUnits, kg/m**3
Fri 5/4/12 15:07:24: SimpleTaskDispatcher6: WARN : com.ptc.windchill.uwgm.proesrv.util.UwgmNDUtilities - UwgmNDUtilities.parseUnit :: unitB lookupSymbol = kg
Fri 5/4/12 15:07:24: SimpleTaskDispatcher6: WARN : com.ptc.windchill.uwgm.proesrv.util.UwgmNDUtilities - UwgmNDUtilities.parseUnit :: unitB 2 = kg, pow = 1
Fri 5/4/12 15:07:24: SimpleTaskDispatcher6: WARN : com.ptc.windchill.uwgm.proesrv.util.UwgmNDUtilities - UwgmNDUtilities.parseUnit :: unitB lookupSymbol = m
Fri 5/4/12 15:07:25: SimpleTaskDispatcher6: WARN : com.ptc.windchill.uwgm.proesrv.rrc.RRCContentHelper - RRCContentHelper.fillContentInfo :: 5712-133-032.prt: Skipping content item with role - THUMBNAIL3D
Fri 5/4/12 15:07:25: SimpleTaskDispatcher6: WARN : com.ptc.windchill.uwgm.proesrv.rrc.RRCContentHelper - RRCContentHelper.fillContentInfo :: 5712-133-032.prt: Skipping content item with role - THUMBNAIL_SMALL
Does anyone have any idea why this might occur?
I tried a PTC recommended setting:
xconfmanager -s log4j.logger.com.ptc.windchill.uwgm=ERROR -t C:\ptc\Windchill_9.1\Windchill\codebase\WEB-INF\log4jMethodServer.properties -p
But it didn't make any difference.
Mike Foster
ATK
May 7, 2012 2:33 PM UTC
log4*.properties are not controlled by xconfmanager.
Also, apparently there is something odd about the handling of
com.ptc.windchill.uwgm.* loggers whereby INFO level is assumed for
com.ptc.windchill.uwgm unless log4jMethodServer.properties explicitly
sets the level to something /more /verbose than INFO. This means that
you will want to set the log level for child loggers to something less
verbose to rectify this, e.g. set the log level for
com.ptc.windchill.uwgm.proesrv to ERROR.
Jess Holle
On 5/7/2012 8:28 AM, Foster, Mike (Goleta) wrote:
> All,
> map = {kg=1, m=-3}
> -p
> Thanks,
> Mike Foster
> ATK
May 8, 2012 4:21 PM UTC
https://www.ptc.com/appserver/cs/view/case.jsp?n=10583668}
The ultimate solution was to restart the server. Since then, I have had no issues.
Jun 18, 2015 7:44 AM UTC
Hi Ned,
I am facing the same issue.
I do not have access to the article, can you share the same in PDF format for my reference.
Murthi
Jun 18, 2015 6:09 PM UTC
The resolution to the case in Ned's link was to restart Windchill. Though, that shouldn't be necessary if you can figure out which logger is causing the high amount of logging, and reset that back to it's default level. What sort of messages are you seeing filling up your MS log? Are they the same com.ptc.windchill.uwgm.proesrv that Mike was seeing? If so, try adding the line to log4jMethodServer.properties that Mike mentioned below.
May 9, 2012 2:59 PM UTC
Thanks to Jess for the fix:
I added the following line to the log4jMethodServer.properties file in C:\ptc\Windchill_9.1\Windchill\codebase\WEB-INF and the excessive logging seems to have stopped:
log4j.logger.com.ptc.windchill.uwgm.proesrv=ERROR
Mike Foster
