Apr 20, 2017 10:25 AM UTC
MethodServer fails to start with error "Failure to start manager wt.index.StandardIndexPolicyManager"
Hi guys,
When I try to start Windchill services, I get this error in MethodServer logs:
ERROR [main] wt.method.server.startup.services  - Failure to start manager wt.index.StandardIndexPolicyManager
wt.services.ManagerException: Couldn't initialize Index manager.
Nested exception is: wt.util.WTException: java.lang.NullPointerException
Nested exception is: java.lang.NullPointerException
At the same time, I get this error in BackgroundMethodServer logs:
Nested exception is: wt.pom.ObjectLockedException: The Repository -  object is already locked in the database.
Nested exception is: java.sql.SQLException: ORA-00054: resource busy and acquire with NOWAIT specified or timeout expired
I opened a case to tech support but they don't seem to be able to help me. So, I come to you today and I REALLY hope that you can help me.
For information, we made a rehost from another Windchill server (database + LDAP people node) and we cannot start Windchill since this time.
Thank you all.
Florent
2-Explorer
Apr 20, 2017 12:02 PM UTC
Hi Florent,
It looks like that Repository table is locked by another session. Did you verify whether you have the right values for database properties in Windchill/db/db.properties? specifically wt.pom.dbUser, dbHost, dbService?
Regards
Binesh
flemoine1-VisitorAuthor
Apr 20, 2017 12:56 PM UTC
yes, all the database values are correctly set.
I already asked my db admin to restart the database but the problem is still here. I deactivated the background methoserver but it still fails to start with the same error in the logs.
