Apr 25, 2023 5:08 AM UTC
Modified By cannot be changed. Constraint Violation in isUpdateValid()
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.2
There is an attribute called modified by for EPM object under visualization and attribute group and I want to change the value of that attribute through data utility
Here are the errors that I faced
com.ptc.core.meta.container.common.ConstraintException: The value for Modified By cannot be changed. Constraint Violation in isUpdateValid()
    HelesicPetr
    Apr 25, 2023 5:56 AM UTC
    Hi @DA_10350817
    I guess the reason is that you use method that do not allow you to modify the attribute without checkin/out .
    You should provide a code what you use and so on. This error does say nothing.
    Just that you are traying to change attribute and your change is not valid for update...
    PetrH
